JavelinSST71
Mar 04, 2026Guide
Unable to view/access XR1000 USB Storage in Windows Pro 11 File Explorer
Setting up a new Windows Pro 11 laptop. I want to use Windows File Explorer to view and access all folders/files within my WD External HD (connected to XR1000 through USB). Environment Details: ...
- Mar 17, 2026
I'm back working on this issue! It appears, from all I've read, that it is a problem with a Microsoft update. I was able to finally follow the link provided by StephenB - and successfully mapped my WD hdd 1021 (through USB port on XR1000) and have access to all folders/files! Here are the steps I followed:
- Ran Powershell as administrator
Get-SMBClientConfiguration (to verify EnableInsecureGuestLogons was set as False and RequireSecuritySignature was set as True)
Ran the following
Set-SMBClientConfiguration -EnableInsecureGuestLogons $true
Set-SMBClientConfiguration -RequireSecuritySignature $false
- Restarted computer
- Opened File Explorer and mapped to \\readyshare\USB_Storage
Thanks to everyone for your help and support!
Mar 04, 2026Guru - Experienced User
JavelinSST71
Mar 04, 2026Guide
Thank you. I'm working on following your directions and will apologize up front as I'm a Grandmother working to setup this new laptop, and this is the last piece.
I have completed the steps you provided, and also tried the solution that worked for Xuul. Unfortunately things are still as they were and I'm unable to access the folders/files on the external hard drive.
