TheHonestTiger's avatar
Jun 23, 2023
Unidentified MAC address in logs
Since my router and VM hub 4 didn't cooperate whilst my hub was in modem mode I had to change it back to normal. So I followed some steps from another post about using the WAN IP from my XR500 and put it into the DMZ on my hub. Ever since I did this I have been losing connection and getting a "[WLAN access rejected: incorrect security] from MAC address 90:98:77:4e:1f:ad, Friday, June 23, 2023 19:00:11" every few minutes, however, none of my devices have this MAC address.
  • Do you have a TV that connects to the internet? If so it will be that as it belongs to a TV manufacturer. Are you losing connection on all devices?
    • TheHonestTiger's avatar
      TheHonestTiger
      Yes but it's not got that MAC address and yeah, every device connected to my router has broadband connection but no internet access.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        It's the OEM (Original Equipment Manufacturer) rather than the brand like Panasonic etc and it will have its own MAC address which can sometimes show. It shouldn't be causing a disconnect though, is there anything else in the log at the times of the disconnects?
