Alica11WTD's avatar
Alica11WTD
Updating Firmware R7800, how?
So i've found there is a hotfix firmware update, and i cant uptade via phone app cuz it dosn't even show it there.
Can i do it on my pc?
  • FURRYe38's avatar
    Th R7800s IP addresss should be 192.168.1.1 if your using it's default IP configuration.
  • FURRYe38's avatar
    Use your Pc and a wired connection to the router. Download the FW file and apply it thru the routers web page. I recommend using FireFox or Opera to do this.
    • Alica11WTD's avatar
      Alica11WTD
      So i've downloaded the firmware form netgear site its called R7800-V1.0.2.63_beta and its a img file
      So i just connect to the router with wire and whats the router web page, do you meant the http://192.168.100.1 one!?
      Thanks
      • FURRYe38's avatar
