parasmrut
Feb 23, 2023Follower
Upnp doesn't work on ps5 - Netgear Nighthawk xr500
Please fix this. I dont want use port forwarding I have destiny on pc and ps5 both it doesn't work. Please have upnp working, my nat type shows as strict ... other game son ps5 like apex and warz...
Netduma-Liam
Feb 23, 2023NetDuma Partner
Good advice above.
Are you using Geo-filter? If so, could you please disable filtering mode as a test and see if your NAT type in game goes to open?
