faruk_prlk's avatar
Nov 08, 2022
upnp error
Hello, I am using netgear xr500. After connecting my Xbox series x console to the router, when I enter the game on Xbox, it shows upnp error, nat type is good, how can I solve this problem, thanks
  • FURRYe38's avatar
    Please post a screen capture of what your seeing on this...
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    • faruk_prlk's avatar
      faruk_prlk
      Guide
      Thanks for your answer, I have the latest version of my xr500 device, modem keenetic omni dsl kn2011, I don't use static ip, I use cat7 ethernet cable, what would you recommend me to do?
  • Those two statements kind of contradict each other, where is it showing UPnP error exactly? Are you having issues in game?
