Gunny6996's avatar
Gunny6996
Follower
Mar 22, 2023
Upnp issue
I’m on firmware 58 and my upnp being on is a real pain in the neck I can’t figure out how to turn it off I’m not sure if updating to the latest will fix the issue and I also can’t afford it to change all my settings any help
  • FURRYe38's avatar
    What NG product are you referring too?
    What is FW 58?
  • What's the issue you're having exactly with it not turning off? On the UPnP page there is an option to disable it.
