ArtVanderlay's avatar
ArtVanderlay
Using Hybrid VPN with Torguard
I'm attempting to use Torguard with my Netgear Nighthawk XR500 Router. I'm requesting details for what type of config dumaOS needs.
I'm running Firmware version CR500 V2.3.2.114
When creating the config on torguard's website I have the options listed in the screenshot. I have attempted all options without success.
Please guide me in a more concret way of understanding what config file is needed for dumaOS. Torguard is a major VPN provider. I hope there is more details how to use their service on Netgear routers.
  • Thanks for posting!
    Could you also send over the Open VPN file that's generated with this configuration? I'm entirely sure if it will work with multiple VPN servers selected, could you see if you have more success just selecting one when generating the configuration file?
    • ArtVanderlay's avatar
      ArtVanderlay
      It's as if it has a difficult time resolving us.atl.torguard.com:1912
      client
      dev tun
      proto udp
      remote us-atl.torguard.com 1912
      remote-cert-tls server
      auth SHA256
      key-direction 1
      setenv CLIENT_CERT 0
      <tls-auth>
      -----BEGIN OpenVPN Static key V1-----
      770e8de5fc56e0248cc7b5aab56be80d
      0e19cbf003c1b3ed68efbaf08613c3a1
      a019dac6a4b84f13a6198f73229ffc21
      fa512394e288f82aa2cf0180f01fb3eb
      1a71e00a077a20f6d7a83633f5b4f47f
      27e30617eaf8485dd8c722a8606d56b3
      c183f65da5d3c9001a8cbdb96c793d93
      6251098b24fe52a6dd2472e98cfccbc4
      66e63520d63ade7a0eacc36208c3142a
      1068236a52142fbb7b3ed83d785e12a2
      8261bccfb3bcb62a8d2f6d18f5df5f36
      52e59c5627d8d9c8f7877c4d7b08e19a
      5c363556ba68d392be78b75152dd55ba
      0f74d45089e84f77f4492d886524ea6c
      82b9f4dd83d46528d4f5c3b51cfeaf28
      38d938bd0597c426b0e440434f2c451f
      -----END OpenVPN Static key V1-----
      </tls-auth>
      resolv-retry infinite
      nobind
      cipher AES-128-CBC
      auth-user-pass
      compress
      ncp-disable
      tun-mtu-extra 32
      <ca>
      -----BEGIN CERTIFICATE-----
      MIIDMTCCAhmgAwIBAgIJAKnGGJK6qLqSMA0GCSqGSIb3DQEBCwUAMBQxEjAQBgNV
      BAMMCVRHLVZQTi1DQTAgFw0xOTA1MjExNDIzMTFaGA8yMDU5MDUxMTE0MjMxMVow
      FDESMBAGA1UEAwwJVEctVlBOLUNBMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIB
      CgKCAQEAlv0UgPD3xVAvhhP6q1HCmeAWbH+9HPkyQ2P6qM5oHY5dntjmq8YT48FZ
      GHWv7+s9O47v6Bv7rEc4UwQx15cc2LByivX2JwmE8JACvNfwEnZXYAPq9WU3ZgRr
      AGvA09ItuLqK2fQ4A7h8bFhmyxCbSzP1sSIT/zJY6ebuh5rDQSMJRMaoI0t1zorE
      Z7PlEmh+o0w5GPs0D0vY50UcnEzB4GOdWC9pJREwEqppWYLN7RRdG8JyIqmA59mh
      ARCnQFUo38HWic4trxFe71jtD7YInNV7ShQtg0S0sXo36Rqfz72Jo08qqI70dNs5
      DN1aGNkQ/tRK9DhL5DLmTkaCw7mEFQIDAQABo4GDMIGAMB0GA1UdDgQWBBR7Dcym
      XBp6u/jAaZOPUjUhEyhXfjBEBgNVHSMEPTA7gBR7DcymXBp6u/jAaZOPUjUhEyhX
      fqEYpBYwFDESMBAGA1UEAwwJVEctVlBOLUNBggkAqcYYkrqoupIwDAYDVR0TBAUw
      AwEB/zALBgNVHQ8EBAMCAQYwDQYJKoZIhvcNAQELBQADggEBAE79ngbdSlP7IBbf
      nJ+2Ju7vqt9/GyhcsYtjibp6gsMUxKlD8HuvlSGj5kNO5wiwN7XXqsjYtJfdhmzz
      VbXksi8Fnbnfa8GhFl4IAjLJ5cxaWOxjr6wx2AhIs+BVVARjaU7iTK91RXJnl6u7
      UDHTkQylBTl7wgpMeG6GjhaHfcOL1t7D2w8x23cTO+p+n53P3cBq+9TiAUORdzXJ
      vbCxlPMDSDArsgBjC57W7dtdnZo7gTfQG77JTDFBeSwPwLF7PjBB4S6rzU/4fcYw
      y83XKP6zDn9tgUJDnpFb/7jJ/PbNkK4BWYJp3XytOtt66v9SEKw+v/fJ+VkjU16v
      E/9Q3h4=
      -----END CERTIFICATE-----
      </ca>
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Could you make a config for OpenVPN version 2.3.4 and then see if it works, if not post that please and hopefully with a few edits we can get it working
