4Scarrs_Gaming's avatar
Sep 03, 2019
VLAN tagging on WAN port SFP+
I need to create a VLAN 35 for my ppoe connect to my ISP. However, I do not see for the life of me how I can create a VLAN and tag the WAN port. I am using a SFP+ connection.
  • Go to Settings > Advanced Settings > VLAN/Bridge Settings > Enable VLAN/Bridge Group > By VLAN Tag Group > Add
    Hopefully that's what you're looking for
    • 4Scarrs_Gaming's avatar
      4Scarrs_Gaming
      That will only allow me to tag ports 1-6 and not the wan port. My ISP requires VLAN 35 on the WAN port.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        If you edit the internet one there already, it says all wired ports, does that not work at all?
