buffalo418
Jan 07, 2019Tutor
VLANs on Nighthawk Routers
Is it possible to setup VLANs within the OS of the XR500? Ideally create two networks that are truly separate from each other where devices on each cannot see or access each other. I see there is a VLAN/bridge but does that mean the only way you can have a VLAN also enables a bridge? If that is the case I assume it will bypass the NAT, which someone may not want. Or mabe it is possible to have a VLAN without a bridge, therefore utilizing the NAT. If anyone has done this please let me know. Also any documentation is helpful. Cheers!
There is VLAN on my XR450:
VLAN / Bridge SettingsWired Ports Wireless (if required; range: 1~4094) Found under Settings/Advanced Settings/VLAN_Bridge Settings
- Netduma-FraserNetDuma PartnerAlso assuming you do this QoS may not run effectively as we've discovered there may be a bug there that needs fixing.
A reason to have a VLAN or even separate network is for IoT devices. Has anyone accomplished this config ?
