lushka's avatar
lushka
Guide
May 23, 2018
VPN and Geolocation
Hey Guys,
Kinda new to this. Quick question. If I'm running a VPN connection via my router, is there a possibility to check my ping  numbers for the lobby that I'm joining via the Geolocation R-app?
Thanks
  • Hi lushka, with the VPN enabled the Geo-Filter will not work correctly. We're in the middle of testing our VPN Hybrid solution which may also resolve this issue depending on how it is used.
  • Hi.
    If you select the host/server on the geo map it should display the ping below the map if Auto Ping Host is ticked!
    • lushka's avatar
      lushka
      Guide
      Hi,
      Unfortunately, it's not showing anything on the Geo map when the VPN option is active. As soon as it is switched off, I see all lobby members on the geo map.
      Thanks
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
