Phantomblu
Sep 19, 2022Apprentice
VPN Setup XR500 V2.3.2.134 Problema
Good morning . I state that I updated to the last firmware XR500 V2.3.2.134 and I reset the settings, I set the VPN with the parameters I have in Purevpn, but I can't log in in any way. This from my XR 500 log router:
VPN Setup
Attiva
Blocca traffico in caso di disconnessione della VPN
Mon Sep 19 12:16:52 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 24 2022 Mon Sep 19 12:16:52 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Mon Sep 19 12:16:52 2022 WARNING: No server certificate verification method has been enabled. See ..... for more info. Mon Sep 19 12:16:52 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Mon Sep 19 12:16:52 2022 TCP/UDP: Preserving recently used remote address: [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:52 2022 Attempting to establish TCP connection with [AF_INET]5.254.88.170:80 [nonblock] Mon Sep 19 12:16:53 2022 TCP connection established with [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:53 2022 TCP_CLIENT link local: (not bound) Mon Sep 19 12:16:53 2022 TCP_CLIENT link remote: [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:53 2022 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this Mon Sep 19 12:16:53 2022 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1560', remote='link-mtu 1552' Mon Sep 19 12:16:53 2022 WARNING: 'cipher' is used inconsistently, local='cipher AES-256-CBC', remote='cipher AES-256-GCM' Mon Sep 19 12:16:53 2022 WARNING: 'auth' is used inconsistently, local='auth SHA1', remote='auth [null-digest]' Mon Sep 19 12:16:53 2022 [Secure-Server] Peer Connection Initiated with [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:54 2022 AUTH: Received control message: AUTH_FAILED Mon Sep 19 12:16:54 2022 SIGUSR1[soft,auth-failure] received, process restarting Mon Sep 19 12:16:59 2022 WARNING: No server certificate verification method has been enabled.
VPN Traffic
- Netduma-FraserNetDuma PartnerIf you're using the basic setup then it's likely we need to update the configs available, get the config file for the server you want to connect to directly from PureVPN, then use it with the Advanced Setup and that should allow you to get connected.
- PhantombluApprentice
The Setting in Purevpn and with Port Forwarding
My log with XR 500 on Purevpn VPN Setup:VPN Setup
AttivaBlocca traffico in caso di disconnessione della VPNMon Sep 19 12:16:52 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 24 2022 Mon Sep 19 12:16:52 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Mon Sep 19 12:16:52 2022 WARNING: No server certificate verification method has been enabled. See.... for more info. Mon Sep 19 12:16:52 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Mon Sep 19 12:16:52 2022 TCP/UDP: Preserving recently used remote address: [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:52 2022 Attempting to establish TCP connection with [AF_INET]5.254.88.170:80 [nonblock] Mon Sep 19 12:16:53 2022 TCP connection established with [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:53 2022 TCP_CLIENT link local: (not bound) Mon Sep 19 12:16:53 2022 TCP_CLIENT link remote: [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:53 2022 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this Mon Sep 19 12:16:53 2022 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1560', remote='link-mtu 1552' Mon Sep 19 12:16:53 2022 WARNING: 'cipher' is used inconsistently, local='cipher AES-256-CBC', remote='cipher AES-256-GCM' Mon Sep 19 12:16:53 2022 WARNING: 'auth' is used inconsistently, local='auth SHA1', remote='auth [null-digest]' Mon Sep 19 12:16:53 2022 [Secure-Server] Peer Connection Initiated with [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:54 2022 AUTH: Received control message: AUTH_FAILED Mon Sep 19 12:16:54 2022 SIGUSR1[soft,auth-failure] received, process restarting Mon Sep 19 12:16:59 2022 WARNING: No server certificate verification method has been enabled. See ... for more info. Mon Sep 19 12:16:59 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Mon Sep 19 12:16:59 2022 TCP/UDP: Preserving recently used remote address: [AF_INET]5.254.88.170:80 Mon Sep 19 12:16:59 2022 Attempting to establish TCP connection with [AF_INET]5.254.88.170:80 [nonblock] Mon Sep 19 12:17:00 2022 TCP connection established with [AF_INET]5.254.88.170:80 Mon Sep 19 12:17:00 2022 TCP_CLIENT link local: (not bound) Mon Sep 19 12:17:00 2022 TCP_CLIENT link remote: [AF_INET]5.254.88.170:80 Mon Sep 19 12:17:01 2022 event_wait : Interrupted system call (code=4) Mon Sep 19 12:17:01 2022 SIGINT[hard,] received, process exiting Mon Sep 19 12:17:04 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 24 2022 Mon Sep 19 12:17:04 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Mon Sep 19 12:17:04 2022 WARNING:VPN Traffic
- Netduma-FraserNetDuma PartnerI've responded to you here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/VPN-Setup-XR500-V2-3-2-134-Problema/m-p/2257631
