DalZ64
Jul 25, 2022Follower
Water in internet cable XR500
Woke up, the power light and the two LAN lights on my router were blinking white, there was no connection to either of my devices and the wifi was turned off. My first instinct was to restart the rou...
Netduma-Fraser
Jul 26, 2022NetDuma Partner
Either the cable you replaced the internet cable with isn't cable of higher than 100Mbps, in which case replacing that with one that can achieve higher will fix it or it's possible the port is now faulty but I would expect it wouldn't work at all rather than just limit you. I'd suggest unplugging the router from power for 10 minutes, then plug in, wait 2 minutes, perform a factory reset, wait 2 minutes and see if you're still limited after that.
