LukeJ's avatar
LukeJ
Follower
Jul 07, 2025
Wifi network name changed and no pw requirement
I just had this happen to mine today but mine rebooted its self then changed both wifi names to Netgear with no password, and no the Default SSID is Netgear## in my case is NETGEAR96/-5G, I also want to know what happened.
  • FURRYe38's avatar
    What Firmware version is currently loaded?\
    Is your XR model the v1 or v2 version?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Factory reset and setup from scratch using a wired PC and web browser?
    https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
  • It's very likely that it lost power and so actually did a partial reset. Set it up again, change all your settings, reboot from the interface and wait 4 minutes before accessing and it should be fine.
