LukeJ
Jul 07, 2025Follower
Wifi network name changed and no pw requirement
I just had this happen to mine today but mine rebooted its self then changed both wifi names to Netgear with no password, and no the Default SSID is Netgear## in my case is NETGEAR96/-5G, I also want to know what happened.
- Netduma-FraserNetDuma Partner
It's very likely that it lost power and so actually did a partial reset. Set it up again, change all your settings, reboot from the interface and wait 4 minutes before accessing and it should be fine.
What Firmware version is currently loaded?\
Is your XR model the v1 or v2 version?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Factory reset and setup from scratch using a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
