brew_me's avatar
brew_me
WiFi resetting daily
Hello,
I have the latest XR1000 gaming router (option wasn't availble to select).  Almost everyday or every other day, I need to reset my router.  All the lights are on the router as if I'm getting a connect but my wifi isn't working.  If I plug into the lan the internet is working.  So around 5am my wifi stops working and I know this without checking because my security camera goes offline.  I don't have any fancy setting.  Matter of fact it's the same setting as if you turn it on right out of the box.  I've done a factory reset multi times and it still hasn't fix the problem.
Any thoughts that would help solve this problem?
Thanks,
Brew
  • Try disabling Smart Connect and connecting those devices manually for 2.4GHz and see whether they sustain a connection.
    • brew_me's avatar
      brew_me
      Smart Connect is disabled.  All of my devices are on 2.4G except for my gaming pc which is on 5G.  All wireless connections do not work, but the LAN connection does.
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        Do you have Armor enabled? If so could you please disable it?
        What firmware version are you currently running?
