Fabi1997
Aug 10, 2020Follower
With Fibre no connection Xr500
My Xr500 is connected to a media converter because it's not Fibre compatible. Converter is connected with the Wan port. Do I have to change something in the router settings? Because internet provider gave me a username and Passwort for the internet. I have no internet connection at the moment :( I need help
1 Reply
- Netduma-FraserNetDuma PartnerYou need to select the login option in Settings > Internet Setup, then apply and you should get the internet.
