mebaby333's avatar
Jan 16, 2019
Xbox One X NAT Type Unavailable
Good Day!,
I am having an issue where the NAT Type on my Xbox One X will go to Unavailable "Could not connect to the Toledo Servers".  When i turned off the Geo Filter and wait about 2 minutes, the Xbox can connect and i can join an Audio Chat.  I am running a version of software provided by support (V2.3.2.26) which fixed the LAN ports from dropping and turning off.  I seems like the Geo filter is blocking the access to Xbox Toledo servers.
Thanks,
Dave
  • FURRYe38's avatar
    What FW is currently loaded?
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
    How is the xbox connected to the router? Wired is preferred.
    Set up a IP address reservation for the console ON the router.
    Is Instant ON enabled? Please disable this and report any changes.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Is it preventing you joining any games? If not all you need to do is add your friends to your allow list in order to chat with them. Do you see anything blocked on the Geo-Filter when you don't get a teredo IP address?
      • mebaby333's avatar
        mebaby333
        Tutor
        I do not see a block but i see a icon pop up on the map when it is searching for NAT, which looks like a dedicated server... When i turn the geo filter off, it takes about 2 minutes and the NAT type goes to open, and then i can turn back on the filtering.
