jame0174
Jul 27, 2022Tutor
xr 1000 high ping
when i use the xr1000 i get high pings.But when i use the duma r2 i get low ping of 13 .my ping with the xr 1000 is 37.I am using the same set up any help would be great.
- Netduma-LiamNetDuma Partner
How are you measuring your ping exactly? Are you looking in-game or are you checking using something else?
Are you using QoS? If so, could you please share your configuration?
If you're using Geo-filter, could you please also share your configuration for that?
- jame0174Tutor
I am using speedtest.net both routers are set up alike.same qos same congestion control .I pay for 950 down and 40 up i also noticed in game ping is also higher on the xr1000 compared to the r2.I don't use strict mode or filtering
Could you please share your QoS configuration? Just attach a screenshot if that's easier.
Are all device on the network connected to the XR/R2 when you're testing? Or do some devices still connect to the ISP router/modem?
