JOHN2N's avatar
JOHN2N
Tutor
Jan 17, 2023
XR 1000 internet setup to wifi
Is it possible to hook up XR1000 to internet without using ethernet cable. I used cable to setup but would prefer to use wifi for better location and lack of wired connection. How do I do it? Thanks. Im ok using it as an wifi extender if I need to.
  • JOHN2N's avatar
    JOHN2N
    Jan 18, 2023
    Thanks, I will get a powerline adapter.
  • FURRYe38's avatar
    The XR series don't support wireless bridging so this is not supported. XR routers need a modem or ONT to connect to via ethernet?
  • It does need to be connected via ethernet cable. You could use a powerline adapter from the ISP router and then connect the XR1000 into that but it has to get a wired connection in some way.
    • JOHN2N's avatar
      JOHN2N
      Tutor
