RaysNation
Feb 23, 2022Aspirant
XR 500 - High ping under load
Hi! So I have this problem with very high ping under load. Speed and ping test is great, but download under load has very high spikes.
A friend of mine has the same router and internet actually and he always gets A+ and his gaming has very little lag/delay while I can barely play. Could anyone please help?
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with Nighthawk gaming (XR series) router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
Thank you. - plemansGuru - Experienced User
You'll get better results in the pro-gaming forum that your router is.
The guys on there are very responsive and helpful.
Nighthawk Pro Gaming Routers - NETGEAR Communities
include what modem/gateway the router is connected to, the firmware you're on, if its specific games with issues, and what settings you're using for qos
