NukeBoom's avatar
NukeBoom
XR 500 can't connect to server or DLAN over WIFI
Hallo,
i have problem to access my plex server or dlan server or haxball server over WIFI.
Server is in Ethernet.
Can somebody helps me ?
Best Regrads
Nuke
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Pro Gaming Routers - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
  • Try disabling QoS completely from the Anti-Bufferbloat menu and see if that helps at all.
      • NukeBoom's avatar
        NukeBoom
        Where's the wireless isolation checkbox like on my old router?
