Willback15's avatar
Willback15
Follower
Sep 21, 2022
XR 500 keeps rebooting
So my XR 500 just started reseting multiple times a day. I got it in april and had no issues but lately it has gotten bad. Ive tried hard reset and changing the wall outlet but nothing. The wifi from the router will go out and then like 30 seconds later all the lights will shut off and it will start rebooting.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Be sure to change the default IP address pool range to 192.168.1.100 to .200. Apply an reboot the router.
  • It sounds like the power adapter may be faulty, do you have another similar powered adapter you could try to see if it works?
