PhillyEagles44's avatar
Jul 01, 2020
Xr 500 slow internet speeds when a few devices connect
So I recently upgraded from a AC 1750 router to my new XR 500 Nighthawk. I pay for 400 mbps internet and when I run a speed test I usually get around 340-320 mbps. Now I live in a house with a couple of buddies and we each have a smart tv and a couple tablets and some pc’s in the house. When we are all home and try and each do our own thing aka some guys watching Netflix, I usually am on my pc watching twitch, one buddy will be on Xbox and our internet completely tanks. The twitch streams start lagging, Netflix starts buffering, Xbox has long wait times. When I had the Ac 1750 router this was never a issue. Now that I am using the XR500 it’s become a nightly issue. I thought this would be a some what of a improvement but it hasn’t been so far. I’ve tried to search the threads for someone with a similar post But haven’t seen any. I have disabled the anti buffer in Qos page with no help. And am honestly lost at what to do next any help would be greatly appreciated
  • What is the XR connected to - a modem/router combo or just a modem? If the former, are there devices connected to that also? As I would recommend ALL devices are connected to the XR. Then I would recommend you re-enable QoS, make sure you've put the correct speeds in Bandwidth Settings. Then use 'Always' for Anti-Bufferbloat with 70% set for both download and upload. See how you get on then.
    • PhillyEagles44's avatar
      PhillyEagles44
      Thank you for the reply, and yes it’s connected to just a modem, and there is only my house phone line connected to modem besides the XR, and two things (my pc and one smart tv) are hard wired to the XR thru cat 6 cable, and I used to have the anti buffer on but it seemed like it was much worse with it on then with it off, but I will for sure give it a shot
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Do give it a go as that feature was designed to combat the very situation you've described.
