Rjaaayyy's avatar
Rjaaayyy
Xr 500
I have an installation stopped problem on my xbox, not allowing it to update or download games consistently . After all troubleshooting on the Xbox and even a new Xbox it still persist. Any idea what networking problem it could be?
  • FURRYe38's avatar
    Is game consoles wired or wireless connected to the XR500 router? Ethernet is preferred.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Be sure to disable any QoS on the XR router temporarily to help check this.
