Misanthrope
Aug 14, 2020Aspirant
XR 700 Teredo Issues
I recently switch from xr500 to xr700. I have ATT fiber, so I’m stuck using their gateway, unfortunately. It’s a BWG210-700. I setup IP pass through on the gateway for the router.
When I try to connect my xbox one directly to the router I get an “unavailable NAT” or can’t find teredo address error on the Xbox one. If I switch to wireless connection I get an open NAT. Anyone have any solutions to this issue? Would love for it to be wired. Thanks!
- Netduma-FraserNetDuma PartnerGo to WAN Settings and change NAT to Open, does it then work correctly on the Xbox?
- MisanthropeAspirantIt does not work. I still get an unavailable NAT type.
- Netduma-FraserNetDuma PartnerIf you disable the Geo-Filter does it give you a NAT reading?
