simashford79
Aug 05, 2022Tutor
XR1000 - can't access QoS options
RPC error 'ERROR_VALIDATION': Validation failed for 'autothrottle'
Anyone else come across this one? Constant loading circle on the RAPP.
Same after a reboot, latest firmware..
- Netduma-FraserNetDuma PartnerWhen did this first start to occur, after changing settings, upgrading etc? Are you using Armor? Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
Many thanks for the fast reply!
Not using Armor.
First found this error a couple of nights ago - have attempted the described fix twice already (including retry at 5).
Last month I re-updated the firmware to 1.0.0.64_1.0.49 due to Device Manager issues and advice elsewhere on the forum.
Standard update seemed to do the job, although was prepped to attempt via TFTP if needed.
Now the QoS issue has appeared.
(Just this second checked back at the DM was full of offline devices - but thankfully 'remove' still works ok.)
Just to note - and reason I was drawn to check the QoS;
Speed test at the router is 939.4 Mbps, but all other device test are much less - currently 130.04Mbps
