  • FURRYe38's avatar
    Did you update or send the FW file using a wired PC and web browser?
    Try re-loading the FW file then do a factory reset by pressing the reset button for 10 seconds then release. Clear out all broswer caches then walk thru the setup wizard.
  • What firmware version are you on? What web browser/device are you using to access it? Does it load any of the interface at all? Good advice above.
    • Joe_MS_39565's avatar
      Joe_MS_39565
      Nighthawk XR1000
      FW Version: 1.0.0.58
      BTW - firmware was updated months ago and DumaOS was working fine. Just suddenly stopped working.
      Opera web browser - updated
      • FURRYe38's avatar
