Yessah
Aug 15, 2022Aspirant
XR1000 DumaOS Geo-Filter setup
Whenever I try to change my home location in the Geo-Filter section I get an error. I've rebooted from in the menu, hardware and removed any devices for filtering. It's stuck as the default California location and I'm closer to East coast. I've tried different browsers too. Any tips would be greatly appreciated. I've attached a picture of the error for reference.
Board: XR1000
ModelFirmware Version: 1.0.0.64_1.0.49
DumaOS Version: 3.1.1
- Netduma-FraserNetDuma PartnerHow are you trying to change the location, by typing it or manually clicking on the map? I suspect the error is from the address option and so by clicking the icon to click on the map instead that should work without error
- YessahAspirant
I've tried all ways. I've picked manually and set by general address.
- Netduma-FraserNetDuma PartnerHas it ever worked - when did it first occur? Have you upgraded the firmware recently and if so did you do a factory reset? If you haven't done the reset please do so and see if it works.
