yourKnightmare
Dec 08, 2022Tutor
XR1000 fire stick 4k issues
Hello, I have contacted Amazon about my Fire Stick 4k connecting to my router's 2.4Ghz and 5Ghz wifi. But loses internet connection. So I had received an exchange thinking maybe it was defective, nope same issue. And I am not sure what to do, but I am on the latest firmeware for the XR1000 I factory reset and tried again. no dice. I factory reset the Fire Stick but no dice. All wireless devices inside my home connect to the router just fine with zero issues. and when I connect my fire stick to my phone's wifi hotspot, works flawlessly. So I assume its an issue between firestick and my router. any help would be greatly appreciated. thank you
Make sure you connect it to the 5ghz. 2.4ghz is a slow network and sensitive to interference.
Are you using any special characters in the ssid/password? Try removing them if so as I've seen several IoT devices with issues on those.
Are you using dfs channels for the 5ghz? if so, try using the upper or lower 5ghz channels and not the dfs ones.
not sure what you mean by dfs channels, if you could elaborate and inform that would be great. thank you so much for your response.
- Netduma-LiamNetDuma Partner
Good response above!
Can you also try giving the Firestick a static IP from the DumaOS interface under Settings -> Setup -> LAN Setup and see if it still disconnects?
