Tkbuc
Jun 25, 2023Guide
XR1000 Firmware Update
Hi everyone.
I logged into the Router via the DUMAS OS on my hardwired Desktop. I checked for XR1000 firmware updates and none were found. However, when I go to NetGear's site, I see that XR1000-V1.0.0.68_1.0.54 is available. I am curious as to why the update firmware tool in DUMAS did not find this update.
I am having no issues with my network and prefer not to go through the update/factory reset process, but do you think I should? Is this update critical for me to have?
- microchip8MasterNG sometimes forgets to push updates to their server so the update tool reports no new findings.
Updates usually come with release note. Read it and see if it's critical or not. - KitsapMaster
Most experienced users prefer to manually update the firmware on their routers. Instructions on how are provided here: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
You might find other information in the community dedicated to the Netgear XR series of routers here: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
Possibly a moderator will move your post.
- Netduma-FraserNetDuma PartnerAs above it could be they've forgotten to push the update or in some cases they may want to see how the firmware is received before pushing it to the masses to prevent customer wide issues for example. That update is primarily a security update so I would recommend updating to it, you don't have to do the factory reset if you don't want to but if you then encounter issues I would suggest doing one as your first troubleshooting step.
