paul5680's avatar
paul5680
Xr1000 GEO filter Uncaught SyntaxError: Invalid or unexpected token
OK
  • FURRYe38's avatar
    Not much to go on.
    What browser are you using? Seen in other browsers?
    Be sure to clear out ALL browser caches before entering the routers web page.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
  • When does this occur, upon loading the page, changing a setting? Did it initially happen after changing settings, swapping web browser, upgrading etc?
