Sionrai's avatar
Sionrai
XR1000 Guest Network Broadcasting
Has anyone run across an issue where you specify that the router should not broadcast the Guest Network SSID on the 2.4GHz band but it still does?
Hiding the SSID for the regular wireless network for both bands work (5GHz guest network is off).
Netgear Nighthawk XR1000
Firmware version 1.0.0.58_1.0.44
See below for example configuration:
  • Previous photos did not upload.
    RegularGuestAvailable Networks
    • Netduma-Liam's avatar
      Netduma-Liam
      NetDuma Partner
      I can't see the photos unfortunatley, they're yet to be moderated.
      I believe if you add them as attachments I should be able to see them straight away.
