Blarn_Kranston's avatar
Blarn_Kranston
Apprentice
Sep 06, 2022
XR1000 Issues Constant Crash
Has any resolution been posted for this?  I have reloaded the firmware via tftp, reset to factory default multiple times, I do NOT run Netgear Armor and yet I am still looking at this error RIGHT NOW!  I know if I power cycle my router, it will reset to factory defaults (Again for about the 50th time in the year I have owned it).  Sadly, it is beyond the Netgear replacement period, because I would sent this boat anchor back in a second if i could.  My previous "Gaming router" lasted almost 10 years before I replaced it with this piece of junk.
-Frustrated owner of an "extreme" gaming router.  I guess the extreme related to the amount of frustration it would cause, not stable, high performance it advertized.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What error are you seeing? Please post a screen capture of this error?
    What all do you have connected to the router?
    Have you had Armor enabled ever on this router or never?
    • Blarn_Kranston's avatar
      Blarn_Kranston
      Apprentice
      Hi Furry,
      Netgear XR1000 router.
      Firmware: 1.0.0.64 (most current)
      Comporium 1Gig fiber
      Fiber ONT is an Adtran Total Access 401
      Cable from fiber ONT is a 7 foot Cat6A cable capible of supporting 10 Gig.  All cabled connections to the router use Cat6A or Cat7.
      Netgear armor has NEVER been turned on after my initial setup, as I have heard it caused issues, and I have tried to remember to disable it anytime I have to reset my router.  I verified in the Nighthawk app that my Netgear Armor subscription is expired so I presume it is not active on the router, although I can not verify currently.
      Connections are a myriad of things, laptops, desktop, Roku streaming devices, gaming consoles, smart lights, a printer....usual stuff.
      • FURRYe38's avatar
        What browser are you using here?
        Is this seen in MS Edge or Firefox as well?
        When is the error displayed? On logging into the routers web page?
        If a factory reset is performed and you walk thru the setup wizard with a wired PC and MS Edge or FireFox, is this item still seen?
        If Armor has not ever been enabled, I don't think this would be causing this problem.
        How was the FW updated on this router? Thru the routers web page manually or via Nighthawk app?
