Farhad47
Apr 12, 2022Aspirant
XR1000 NAT type always moderate
Hi i just got the XR1000 but cant get my NAT type open on anything its always moderate i have tried WAN open from secured UpNP enabled/disabled Upnp disabled with manual port fowarding for Warzone but still nothing..my set up is Fibre ONT to the XR1000 with VLAN id conection
Thanks
Thanks
- Netduma-FraserNetDuma PartnerDid you have an Open NAT with your previous router? It sounds like you may have a CG-NAT
- Farhad47AspirantHi thanks for reply i didnt use it for long but didnt try to open it but my NAT was Moderate by default..how do i get rid of CGNAT? do i contact the ISP? Thanks
- Netduma-FraserNetDuma PartnerDouble check if you do have it by following the bottom of this guide: http://support.netduma.com/en/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-open-nat
If you do have it then the only way to get an Open NAT with your existing provider is to purchase a public static IP from them. Otherwise the only other option would be to change ISP.
