egwok's avatar
egwok
Tutor
Feb 14, 2022
Xr1000 Ping heat map cod COLDWAR is not listed
In ping heat map on xr1000 was the call of duty Cold War removed from the list for any reason cause it just disappeared on mine . It’s not on the list of the ping heat map I have tried factory reset and it’s still not showing .see attached file . I also tried resyncynig the cloud under ping heat map with no luck . I’m on firmware xr1000 1.0.0.58_1.0.44
  • Yeah Cold War was removed now that Vanguard is out. That being said, you can use the Vanguard/Warzone map for server information as they're pretty much exactly the same servers.
