seanwilks's avatar
seanwilks
Follower
Jan 07, 2022
XR1000 router is preventing Citrix Receiver app from launching.
This is a strange issue and reproduceable on multiple PCs on my LAN. I have a computer that uses a VPN client to connect to work network, and the local PC connects using RDC to a PC at work. From the remote PC, the Citrix Receiver application opens, and should launch applications, but does not from home. At work (not RDC), the apps launch fine; a coworker is able to launch the apps when RDC from home; the apps launch when the local PC is connected to a phone hotspot instead of the router. So the router is somehow causing the virtual application on a remote PC to fail to connect. I don't know why or how, but I need a resolution.
