LaggyDaWifi's avatar
LaggyDaWifi
XR1000 settings get wiped on factory reset
Hey, I just want you to know that if you factory reset your router and you saved that config file, your settings won't save if you choose to restore the settings, i had to reconfigure my whole SSID & Password, i thought that if you save your whole save config file, it will go back to the settings you had for the Wireless settings!
  • FURRYe38's avatar
    If you had WiFi Settings configured prior to the back up configuration file being generated and saved to file, restoring should bring those back after a factory reset and restore operation.
    • LaggyDaWifi's avatar
      LaggyDaWifi
      I had my settings back up before I saved the file, I had to reconfigure my Wi-Fi settings after I factory reset!
      • FURRYe38's avatar
        So after you reset and applied the backup config from file, the custom wifi settings were not re-applied?
