lenogevne
Aug 30, 2022Follower
XR1000 Setup help & tips!
So I recently upgraded to spectrum gig internet and was recommended the Xr1000. I don't have knowledge about network stuff I don't know how to ask questions nor if im asking the right questions, so...
michaelkenward
Aug 30, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. You are asking fr detailed thoughts on a specific range of upmarket routers rather than the bog standard General WiFi Routers (Non-Nighthawk and Non-Orbi) things covered here.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
