z3thon's avatar
z3thon
XR1000 Spec Sheet?
The XR1000 has a very limited Tech Spec section. I'm looking for information like whether or not it comes with WPA3, what the coverage area is, the different bands it supports 2.4, 5.0, etc.
Speed of the Ethernet ports, 10gig like the XR700 or just gigabit (1gig).
Is there a more comprehensive tech-spec sheet than what the webpage offers?
Thanks!
  • rinthos's avatar
    rinthos
    Sep 17, 2020
    Netgear has shared details at the level you were inquriing about for the XR1000. Please see here:
    https://www.netgear.com/images/datasheet/networking/wifirouter/XR1000.pdf
    For additional details you can likely see some hardware teardowns for the RAX50, which has the same hardware :)
    In short, no 10Gb ports, Yes 2.4ghz and 5ghz dual-band. And yes, supports WPA3.
    Hope this helps.
    Thanks!
  • Not as far as I am aware. Reviews should start coming out soon though so you may find more information then.
    • rinthos's avatar
      rinthos
      Luminary
      Hope this helps.
      Thanks!
