NairoD
May 14, 2023Aspirant
XR1000 UPDATE HELP
I downloaded the new firmware on the netgear's site, https://www.netgear.it/support/product/xr1000#download
but when i try to restore the downloaded file it says the file is .chk when the downloaded file i sactually .cfg file. Anyone has any idea how to fix this and have the latest firmware on my xr1000 router ?
- Netduma-FraserNetDuma PartnerRestoring is re-loading settings from a saved config file, the firmware update is what you want, following the link above will get you sorted
Any progress on this?
