ssssss
Jan 24, 2023Tutor
XR1000 vs XR1000v2: the difference?
Anyone know the difference between these two hardware versions? Thanks,
Try asking in the place reserved for these devices:
Nighthawk Pro Gaming Routers - NETGEAR Communities
- ssssssTutor
- Netduma-LiamNetDuma Partner
There was an issue with supplying some hardware for the XR1000, so they had to use different but comparable hardware instead. The performance will be the same between the two, it's just a case of any new XR1000s purchased will now be 'XR1000v2'.
Does this still use same FW code base and I presume same release FW between the v1 and v2?
