DiscreetLee
Jun 14, 2022Follower
XR1000 won’t load Geo Filter or Ping Heatmap
I’ve tried everything. I’ve tried rolling back updates then updating to the newest firmware, I’ve tried using edge, I’ve tried disabling armor, I’ve tried resetting. I just don’t know what else to do to get these two features working, everything else works fine.
- Netduma-LiamNetDuma Partner
What firmware version are you on currently?
After updating the firmware, have you factory reset the XR? If not I'd suggest doing so as the issue could be related to some old low-level code from an old firmware and may have been carried over to the newer firmware when you upgraded.
Are you getting any error messages when trying to load these two features?
- louie0827Aspirant
Hi,
I have also some trouble getting in the ping heatmap section. The geo filter works, but ping heatmap keeps showing this.
And also can you update the FIFA22 servers on xbox? Recently I keep showing I am getting peer servers when my in game ping is 22ms but my opponent was 8ms. The geo filter showed me my own location which is really weird, can you please look into this?
- Netduma-FraserNetDuma PartnerI can't see your picture as it needs to be moderated, could you attach it directly please? The Geo-Filter doesn't show your location so it was likely just very very close to you. Also the ping can differ between the Geo-Filter & game as the game may include processing delay (which all games have) in their ping calculation.
