hotchili's avatar
hotchili
Follower
Nov 28, 2020
XR300 2.4 network dropping out
Hey,
So for the last month or so I’ve been having a lot of problems with the 2.4 GHz wifi network. My 5 GHz is all working fine, but anything connected via 2.4 ie Nest Cam, Echo, Music Streamer are constantly disconnecting, or worse, losing their set up entirely (music streamer). I go back through set up, see it in the network for a couple of days, then it’s gone.
I’ve just run the network set up on the router again to see if it changed anything but no luck.
I’ve also tried a variety of different channels but that doesn’t make a difference either.
I turned off QoS settings, no different
Please help. No idea what else to do
1 Reply
  • Give those devices reserved IP addresses in LAN Settings and see if that helps. Do you see any entries in the log file when it happens?
