AbaloneBrush's avatar
AbaloneBrush
XR300 could not set up vpn in openvpn
setup the dns and vpn then download the zip from <For Smart Phone>
unzip the the file (4 files in it)
take the client3.ovpn and email to my iphone
and open it in openvpn
then the app  error :  "Failed to parse profile: ca.crt, client.crt, client.key"
is there any step i did it wrong?
or just the router does not support.......
  • I just tried it on my router and with the app and it worked fine. Did you extract the .ovpn file out of the zip folder before you sent it to your phone? Are you using the OpenVPN Connect app or another one?
    • AbaloneBrush's avatar
      AbaloneBrush
      I extract the .opvn from the zip (using winrar)
      but what about the other file? should i do anything about them?
      more info about the system
      Firmware versionXR300 1.0.3.50_10.3.36
      OpenVPN ios ver 3.2.2(3507)
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        All I did was import the .ovpn file into the app and it worked.
