Lukespooner
Dec 13, 2019Tutor
Xr300 geo filter and other problems
Right so i have an xr300 the problems are im constantly getting connected outside of my radius and yes everything is setup exaclly how netdumaos tells you to set up i followed all instructions i leave it in filtering mode at all times etc etc my radius is set exaclly around the uk and it is finding lobbys so easy in bo4 blackout it finds games within seconds of my pressing deploy it shouldnt find games as quick as that then i check where im connected to and its either someone in the states or italy or spain etc etc never connect to anyone in my radius as filtering mode is enabled at all this should be happening i have tried everything from factory resetting the xr300 i have even ran a test sat 50mile radius it still finds lobbys to join and at a 50 mile radius i should find zero lobbys my other gripe with this router is most of the things are displayed as NIL i have no clue what that means but id like some help here before i post a bad review to my youtube channel i bought this router in confidence i would get the best connections at all times to the games i play but up to now it if failing drastically
- Netduma_AlexNetDuma Partner
In the second screenshot you posted, I can see that there's an icon to the right of the radius. This icon (inside a triangle) represents a blocked server, so if these are the icons you're seeing outside of your radius, it's all working normally.
The appearence of the word "nil" all over the place is actually a known bug. Could you let me know what firmware version you're on?
As a test, could you open a private tab in your browser and see if the nil bug is still present?
- Hi net duma alex .. as the host marked in the triangle is a blocked connection inside my radius it never shows anyone that i can click on to see the ping etc etc no one is ever shown inside my radius is there a setting i need to have it on to see this ? Also if it is working correctly how come when i have done certain tests it still finds games very easily even in a 50 mile radius it still finds games when i load into bo4 blackout it may be blocking certain hosts as you say no it never shows the host inside my radius for me to ping
I am on the latest firmware i updated the other day to the latest one the nil bug has been there since i purchased the router .. thanks for the help
