arithor's avatar
arithor
XR300 give DHCP to MAC address again again
I have  XR300   and his DHCP give me lots of error
in monitor LOG I see he give in loop again again in five sec my network new IP and not the same even it is same MAC
and if you look and time it is five sec time he renew the IP
here is copy from the LOG
Wednesday, Jun 03,2020 19:43:02
[DHCP IP: (192.168.1.116)] to MAC address E8:6A:64:AB:BB:70, Wednesday, Jun 03,2020 19:41:44
[DHCP IP: (192.168.1.114)] to MAC address 50:DE:06:78:83:B0, Wednesday, Jun 03,2020 19:41:42
[DHCP IP: (192.168.1.101)] to MAC address E8:6A:64:AB:BB:70, Wednesday, Jun 03,2020 19:41:21
[DHCP IP: (192.168.1.114)] to MAC address 50:DE:06:78:83:B0, Wednesday, Jun 03,2020 19:41:12
[DHCP IP: (192.168.1.112)] to MAC address E8:6A:64:AB:BB:70, Wednesday, Jun 03,2020 19:41:05
[DHCP IP: (192.168.1.108)] to MAC address 50:DE:06:78:83:B0, Wednesday, Jun 03,2020 19:41:00
[DHCP IP: (192.168.1.107)] to MAC address 00:05:CD:2B:6E:52, Wednesday, Jun 03,2020 19:40:48
[DHCP IP: (192.168.1.103)] to MAC address 44:09:B8:98:AE:D4, Wednesday, Jun 03,2020 19:40:46
[DHCP IP: (192.168.1.100)] to MAC address 40:CB:C0:CC:99:0F, Wednesday, Jun 03,2020 19:39:33
[DHCP IP: (192.168.1.100)] to MAC address 40:CB:C0:CC:99:0F, Wednesday, Jun 03,2020 19:33:50
[DHCP IP: (192.168.1.102)] to MAC address 70:EE:50:1B:36:F4, Wednesday, Jun 03,2020 19:33:22
[DHCP IP: (192.168.1.100)] to MAC address 40:CB:C0:CC:99:0F, Wednesday, Jun 03,2020 19:32:48
all this device are connected all the time to switch and there are not powering up in this loop
One device complain that it did not get IP address only GW + DNS info but IP was missing .
I am runing FW 1.0.3.26_10.3.22 , If I go to FW  3.30 and make it factory default my router will have spped around 100mb in speedtest, If I use 3.22  I get around 600   my connection is 1000mb   fiber and I messure speed over lan.
Diffrent router give me speedtest 950 +- 30    so that is one Q, why is my router XR300 SLOW ?
PS if I turn on Traffic meter my router get down in speed to 20 mb   :(
  • Give that device a reserved IP in LAN Settings and shouldn't be a problem. What do you get with QoS disabled in the Anti-Bufferbloat option menu?
    • arithor's avatar
      arithor
      Well Device should only have IP from DHCP when it start
      Not in evrey 20 sec ?
      Anti Bufferbload is NEWER
      Download upload is 1000mb (100%)
      Share Exess is X   share exxess bandwith all device
      ari Thor
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        It's something we're aware of, meanwhile reserved IP should help. On the Anti-Bufferbloat panel, click the 3 horizontal lines in the top left hand corner of the panel and check the tickbox to disable QoS - do you get higher speeds there?
