virtuous
Oct 16, 2020Aspirant
XR300 Not Reaching ISP speeds
Hey all, I've recently purchased the Nighthawk XR300, and have recently started using it but I've noticed that the speeds aren't reaching my expected ISP speeds, 1000mbps. I read on the website specifications that the router can support up to 1.7GBPS, and even more on wired. But how am I only getting 175MBPS on my Note 10+ and even less than that at 58MBPS on my Macbook Air?
Any help would be much appreciated!
- Netduma-FraserNetDuma PartnerHave you entered your expected speeds into bandwidth settings? What are your QoS settings? What is your exact physical setup?
- virtuousAspirant
I'm not sure what you mean by physical setup, but I'll tell you what I know. I have a 1000MBPS NBN Fibre plan, router is plugged directly into the wall's nbn port from the WAN port. I access my internet through wifi on my devices, no ethernet. QoS settings are disabled, and I'm not sure how to access the bandwidth settings.
- Netduma-FraserNetDuma PartnerDo you have a modem/router provided by NBN? In the Congestion Control 3 line option menu you can enter your speeds that you expect, have you done this?
