SaltySenpai's avatar
SaltySenpai
XR300 Router having trouble keeping uploading speeds
So, I've had this router for less then a year, well, damn near a year. Though, as of 2 days ago, its upload speed has dramaticly dropped. I'm normally hitting 10 Mgb/s, but as of late, i'm barely hitting 1.2 Kbs/s.
I'm really not savy when it comes to this, and its really the best I can to describe this. If anyone can help me that would be amazing.
  • plemans's avatar
    Mar 19, 2021
    What arris is it?
    Have you went in to the XR and manually set you upload speed?
  • plemans's avatar
    What modem/gateway do you have?
    Have you tried connecting directly to the modem and testing your speed?
    • SaltySenpai's avatar
      SaltySenpai
      I had done that. Connecting to the modem which is an Arris Surfboard the speeds jumped back up where they were ment to be at.
      • plemans's avatar
        What arris is it?
