RikMeleet's avatar
RikMeleet
XR300 slow internet speeds
My router only gets 80mbps when I use it. I checked the settings and tried different settings. When I put the router in AP mode I get a average of 380mbps. This is all on WiFi. Wired is the same except that the speed in AP mode is 450mbps.
Please help me in my search because at this point I tried everything from disabling geo fencing, anti blufferbloat etc etc al het settings where tried nothing made a change.
  • It sounds like your QoS Settings, in the Anti-Bufferbloat panel, click the 3 line icon in the top left and disable it completely. What speeds do you get then?
    • RikMeleet's avatar
      RikMeleet
      Thank you for the fast response, unfortunately disabling the QoS makes no difference at all. Still around 80mbps. Tested all my cables from the router to the modem, replaced them with new ones. Any other suggestions I can try?
