darkmage0707077's avatar
Sep 18, 2019
XR500 - Brave Browser broken after firmware update
I just recently updated my firmware to the latest version 2.3.2.56, with no apparent issues. However, after attempting to log back in several days later, I find that the router website no longer works with the Chrome-based Brave browser: I will VERY briefly see the usual login menu appear and disappear, where it then takes me to the "cannot authenticate" page that normally appears when you supply bad passwords or cancel out of the prompt (where it requires the router S/N to continue).
I've tried everything from clearing my browser cache to restarting my machine to resetting the router to a full factory reset, and nothing works. The prompt appears fine on other browsers such as Firefox, and it WAS working fine with the previous edition.
Is it possible to roll back to the previous firmware version?
    • darkmage0707077's avatar
      darkmage0707077
      Initiate
      Ah, FINALLY have a chance to login and test, and sure enough, the info in the link about disabling the Chromium setting worked.
      Thank you for your assistance, everyone! Here's hoping this gets fixed in the next version of Chrome!
  • FURRYe38's avatar
    Have you rebooted the PC or device that your broswer is installed on and tried again after the reboot?
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      The link from plemans will likely resolve the issue. We are working on getting that fixed as well.
      You are able to downgrade the firmware without issue but that's not the problem here.
      • Netduma_Alex's avatar
        Netduma_Alex
        NetDuma Partner
        Yes I believe that Brave is based on Chromium, however I don't know if it has the same developer toggles that Chrome has. If you can, you need to disable http-auth-committed-interstitials
